Handling referenced data channels
Posted: Thu Apr 17, 2008 1:28 pm
I would like to handle the correct setting of data, names/codes and parameters to write test channel files where the channels are referenced. The source of the raw data is video analysis.
1. channel = displacement-x within a reference system = vehicle:
main location = HEAD, channel code = 00HEAD000000DSXV
channel file/descriptor "Reference system" = "moving vehicle, alignment to vehicle at T0" (example string)
OK?
2. same as (1) but referenced to the (static) displacement value at T(ref),
calculation before storage of the channel = x’(t) = x(t) – x(Tref):
a constant offset is subtracted from the channel vector,
Is there any descriptor or possibility to indicate this type of pre-calculation in MME 1.5 or 2.0?
Is there any descriptor to enter the (subtracted) offset?
(Please note: this can be necessary not only for displacement but also e.g. for velocity.)
3. same as (1) but referenced to the dynamic displacement of another "point":
calculation before storage of the channel = x’(t) = x(t) – xref(t):
a time-variant offset is subtracted from the channel vector,
Is there any descriptor to enter the source name/code or values of the reference?
Do you recommend to handle it in the MME-2.0 file *.rsi by giving comments to "General description of the reference
coordinate system"?
The .ref files handle the transformation of 3D coordinate systems and are a bit to complex for the requested needs, are they?
Looking forward to your comments!
Alexander Gerhard
OK?
coordinate system"?
Alexander Gerhard
