Channelcode for NKM?
ucarstensen
Company: Faurecia automotive seating GmbH
Post by ucarstensen »
I'm looking for channelcodes for NKM criterion.
The proposal of our anlalyse software is :
S1NKMCIPEPBR00YB / Nkm criterion extension posterior (In Position )
S1NKMCIPEABR00YB / Nkm criterion extension anterior (In Position )
S1NKMCIPFPBR00YB / Nkm criterion flexion posterior (In Position )
S1NKMCIPFABR00YB / Nkm criterion flexion anterior (In Position )
S1NKMCIP00BR00YB / Nkm criterion (In Position )
S1NKMCIPEPBR00YA / Nkm criterion extension posterior (In Position )
S1NKMCIPEABR00YA / Nkm criterion extension anterior (In Position )
S1NKMCIPFPBR00YA / Nkm criterion flexion posterior (In Position )
S1NKMCIPFABR00YA / Nkm criterion flexion anterior (In Position )
S1NKMCIP00BR00YA / Nkm criterion (In Position )
S1NICR00SIBR00XD / NIC
I would like to define the codes due to the TS 13499 but I can't find any proposal.
Is NKMC the correct code for the main location?
Uwe Carstensen
FAS R&D - Global Validation Services
Faurecia Automotive Seating
Garbsener Landstraße 7
30419 Hannover
Germany
uwe.carstensen@forvia.com
Re: Channelcode for NKM?
Dear Uwe,
actually you are right and the NKM result channel codes are not included in the database. Nevertheless they are already covered by the RED E:
??NKMCFA00??00YX
??NKMCFP00??00YX
??NKMCEA00??00YX
??NKMCEP00??00YX
??NKMC0000??00YX
So I would expect that the channels of the corresponding NKM parts would follow this codings:
??NKMCFA00??00YB
??NKMCFP00??00YB
??NKMCEA00??00YB
??NKMCEP00??00YB
??NKMC0000??00YB
I am not sure why their is a IP in your codings. For Nij their are for some dummies different critical intercept values given for In Position and Out-of-Position testing. Therefore we included this in the coding. For the NKM I just know about one set of reference values to be used with the BIORID:
extension -> 47.5 Nm
flexion -> 88.1 Nm
negative and positive shear -> 845 N
So their is no need for the IP in the code. Also I am not sure about the variant with CFC1000 -> ....A. As far as I know the NKM will be prepared with CFC600 -> ...B
... I would propose to move this topic somewhere to the "Additional Codes" board, as this is not explicitly a V 2.0 issue...
Implemented in db 1.6 p5:
??NKMCFA00??00YX / NKM, Flexion Anterior Shear / NKM, Flexion Scherung nach vorn
??NKMCFP00??00YX / NKM, Flexion Posterior Shear / NKM, Flexion Scherung nach hinten
??NKMCEA00??00YX / NKM, Extension Anterior Shear / NKM, Extension Scherung nach vorn
??NKMCEP00??00YX /NKM, Extension Posterior Shear / NKM, Extension Scherung nach hinten
??NKMC0000??00YX / NKM Criterion / NKM-Kriterium
Actually I did not add the codes for any true calculated "channels" (also not available for NIJ,...).
If their is a need I will add them later.
