S2 figure 2011-10-28 revision
Paul Wellicome
Company: HORIBA MIRA Ltd
Post by Paul Wellicome »
I've revised the figures in line with Dive's PDF and colour-coded the channels which swap sides with impact. Also added the note about spine T4 and T12 measurement locations.
ISO-S2_20111028_01.pdf
S2 (Standard Instrumentation - upper body)
(544.48 KiB) Downloaded 1322 times
ISO-S2_20111028_02.pdf
S2 (Standard Instrumentation - lower body)
(536.85 KiB) Downloaded 1310 times
ISO-S2_20111028_03.pdf
S2 (Additional Instrumentation)
(535.4 KiB) Downloaded 1423 times
ISO-S2_20111028_04.pdf
S2 (Static measurements, other channels)
(530.7 KiB) Downloaded 1308 times
ISO-S2_20111028_05.pdf
S2 (additional instrumentation - instrumented arm)
(535.25 KiB) Downloaded 1382 times
Re: S2 figure 2011-10-28 revision
Hello Paul,
in the S2 figure 2 we found a typing error:
wrong: pupic symphisis
right: pubic symphysis
Hello Paul,
instead of the location ILAC LE/RI 00 S2 FO Y it is possible to use the two components
ILAC LE/RI UP S2 FO Y and
ILAC LE/RI LO S2 FO Y.
Return to “SID IIs (S2)”
