RED B (1.6) - Channel Codes - Revision 1
Channel Codes
Attached you´ll find the revised versions of ISO TS 13499 RED B.
ISO TS13499 RED B Version 1_6 Rev1 Channel Codes.pdf
pdf document - version 11.03.2014
(431.07 KiB) Downloaded 2340 times
RED B (1.6) - Channel Codes - Rev 1 (Hotfix1: 2014-06-25)
The Hotfix update of the database 1.6.1 leads to minor changes in the the Enlish Longnames of some QA codes:
For ??CHSTLO00QADSY?, ??CHSTLELOQADSY? and CHSTRILOQADSY? we changed "Upper" to "Lower" in th English Longnames.
So please find attached the updated RED B
ISO_TS13499_RED_B_161_2014-06-25.pdf
(431.23 KiB) Downloaded 1817 times
Return to “RED B (1.6.x / 2.x)”
