ISo MME Database
Access database files
oschaar
Location: Delphi Deutschland GmbH; Delphiplatz 1; 42119 Wuppertal, Germany; Tel.:+49(0)202-291-3325
ISo MME Database
Post by oschaar »
Attached you´ll find the last official release of the ISO-MME database.
This database contains all codes and figures and is able to generate the official RED B and C Documents.
it is splitted in several documents. After copying it you have to set the path to the backend during the first startup. The path to the figures has to be set unter "System-Figures".
Please be so kind and contact me for questions or if you find any data or software bugs.
This software can also be downloaded at ISO standards website
Database release : 2.4
Data release 1.5
ISO TS13499 RED BC MMÉ DB V15 Figures Interior_Airbag.zip
Figures Interior Airbag
(919.77 KiB) Downloaded 1599 times
ISO TS13499 RED BC MMÉ DB V15 Figures Vehicle.zip
Figures Vehicle
(1.85 MiB) Downloaded 1668 times
ISO TS13499 RED BC MMÉ DB V15 Figures Child.zip
Figures Child
(458.03 KiB) Downloaded 1581 times
ISO TS13499 RED BC MMÉ DB V15 Figures Side.zip
Figures Side
(2.28 MiB) Downloaded 1574 times
ISO TS13499 RED BC MMÉ DB V15 Figures Frontal_Rear_Pedestrian.zip
Figures Frontal Rear Pedestrian
(943.28 KiB) Downloaded 1590 times
ISO TS13499 RED BC MMÉ DB V15 Backend.zip
Database Backend
(216.9 KiB) Downloaded 1616 times
ISO TS13499 RED BC MMÉ DB V24 Frontend.zip
Database Frontend
(695.36 KiB) Downloaded 1582 times
Olaf Schaar
Lead Test Engineer
Electronics & Safety Systems
Tel.: +49(0)202-291-3325
Fax.: +49(0)202-291-3419
Mobile: +49(0)151-18223791
eMail : olaf.schaar@delphi.com
Customer Technology Center Wuppertal
ISO MME Database - Addition
The database frontend ISO-MME.mdb doesn't work on our computers.
With Olaf's help I've created the frontend ISO-MME_XP.mdb.
If someone has problems with the original database he should try this version.
ISO TS13499 RED BC MME DB V24 Frontend Alternative.zip
Alternative database frontend
(731.61 KiB) Downloaded 1631 times
Return to “Database (1.5)”
