In the proposal 8 of the main document a Channel Information File (see 6.1) is mandatory if the the Channel subdirectory is used (see 6.4)
In the proposal 8 of the RED A the following specification is used (see 1.2.5):
The descriptive information about all channels has to be stored in the header section of each channel file. It is not necessary to store this data in a redundant channel information file. - 1) If we don't use a Channel Information File we have to change the main document.
- 2) If we don't use a Channel Information File a software system has to read all channel headers.
- 3) If we don't use a Channel Information File there is no compatibility to MME 1.x and a differing handling of the subdirectories.
- 4) If we use a Channel Information File we have redundant information and need rules for the hierarchy/order.
- A) We use no Channel Information File and change the main document.
- B) We use a Channel Information File and the rules described in the proposal 7 RED A 1.2.5 (see below).
- C) I describe another solution.
I prefer solution B.
proposal 7 RED A 1.2.5 :
1.2.5 Channel information
The descriptive information about all channels has to be stored within one channel information file in the Channel- subdirectory or in the header section of each channel file. It is possible to use both at the same time. In this case the information of the channel file overrides the information of the channel information file.
