channel codes of tracking datas
Posted: Wed Aug 25, 2010 8:35 am
by ucarstensen
I'm looking for a definition for channel codes of tracking datas.
In the appendix you find my proposals for all tracking channels we used at faurecia.
I know some tracking points very specially but some are standard.
As important I regard tracking datas of lowspeed tests, for example BioRID.
Are already codes defined?
Bets regards
Uwe Carstensen
Re: channel codes of tracking datas
Posted: Mon Aug 30, 2010 11:34 am
up to now for filmanalysis tracking data no special coding is standardized.
But there are some general rules which can be applied to this kind of codes.
Currently a group of german car manufacturers is working on filmanalysis of whiplash tests.
I will try to get a harmonized list of codes from this group.
For now I will give your my opinion to your proposal
  • channels attached to the seat are not related to the dummy type
  • the FineLocations RI/LE should replace IN/OU
  • LE/RI should be the FineLocation1
  • the CenterofGravity CG is not at the side of the head -> should be MI
For the whiplash procedure this results in the attached proposal
Posted: Wed Sep 01, 2010 6:58 am
by ucarstensen
Thank you very much for this information.
Uwe Carstensen
Posted: Thu Feb 16, 2012 10:42 am
Included on Whiplash figure.
Item closed at on-line meeting 20120216.
