i have prepared a proposal for the coding of the FOCUS head instrumentation. The FOCUS head is used in combination with an standard Hybrid III 50 percentile dummy. The FOCUS head offers detailed force measurements in the face area.
Code /English Name / German name
???HEADFBLEH3FOXA / Head Frontal Bone Left Force X / Kopf Stirnbeinkraft links X
??HEADFBLEH3FOYA / Head Frontal Bone Left Force Y / Kopf Stirnbeinkraft links Y
??HEADFBLEH3FOZA / Head Frontal Bone Left Force Z / Kopf Stirnbeinkraft links Z
??HEADFBRIH3FOXA / Head Frontal Bone Right Force X / Kopf Stirnbeinkraft rechts X
??HEADFBRIH3FOYA / Head Frontal Bone Right Force Y / Kopf Stirnbeinkraft rechts Y
??HEADFBRIH3FOZA / Head Frontal Bone Right Force Z / Kopf Stirnbeinkraft rechts Z
??HEADNB00H3FOXA / Head Nasal Bone Force X / Kopf Nasenbeinkraft X
??HEADNB00H3FOYA / Head Nasal Bone Force Y / Kopf Nasenbeinkraft Y
??HEADNB00H3FOZA / Head Nasal Bone Force Z / Kopf Nasenbeinkraft Z
??HEADEYLEH3FOXA / Head Eye Left Force X / Kopf Augenkraft links X
??HEADEYRIH3FOXA / Head Eye Right Force X / Kopf Augenkraft rechts X
??HEADZBLEH3FOXA / Head Zygomatic Bone Left Force X / Kopf Jochbeinkraft links X
??HEADZBLEH3FOYA / Head Zygomatic Bone Left Force Y / Kopf Jochbeinkraft links Y
??HEADZBLEH3FOZA / Head Zygomatic Bone Left Force Z / Kopf Jochbeinkraft links Z
??HEADZBRIH3FOXA / Head Zygomatic Bone Right Force X / Kopf Jochbeinkraft rechts X
??HEADZBRIH3FOYA / Head Zygomatic Bone Right Force Y / Kopf Jochbeinkraft rechts Y
??HEADZBRIH3FOZA / Head Zygomatic Bone Right Force Z / Kopf Jochbeinkraft rechts Z
??HEADMXLEH3FOXA / Head Maxilla Left Force X / Kopf Oberkieferkraft links X
??HEADMXLEH3FOYA / Head Maxilla Left Force Y / Kopf Oberkieferkraft links Y
??HEADMXLEH3FOZA / Head Maxilla Left Force Z / Kopf Oberkieferkraft links Z
??HEADMXRIH3FOXA / Head Maxilla Right Force X / Kopf Oberkieferkraft rechts X
??HEADMXRIH3FOYA / Head Maxilla Right Force Y / Kopf Oberkieferkraft rechts Y
??HEADMXRIH3FOZA / Head Maxilla Right Force Z / Kopf Oberkieferkraft rechts Z
??HEADMB00H3FOXA / Head Mandible Force X / Kopf Unterkieferkraft X
??HEADMB00H3FOYA / Head Mandible Force Y / Kopf Unterkieferkraft Y
??HEADMB00H3FOZA / Head Mandible Force Z / Kopf Unterkieferkraft Z
These codes will require additional codes just in FL1:
FL1-Code / eng / dt
FB / Frontal Bone / Stirnbein
NB / Nasal Bone / Nasenbein
EY / Eye / Auge
ZB / Zygomatic Bone / Jochbein
MX / Maxilla / Oberkiefer
MB / Mandible / Unterkiefer
A special order for the "LE" and "RI" parts has been chosen here (in FL2) because:
- all codes should be similar and starting with the subsection on the head in FL1
- several measurements are left and right related to the subsection (maxilla,...)
- all additional parts could be made for FL1 that actually has not that as much codes as FL2
Please find attached some images visualizing the design of the focus head.
These codes could also be used to code the force measurements on the THOR dummy head in the future.
Any comment is welcome.
FOCUS Head codes
FOCUS Head codes
- Focus Assy 15_extracted copy.jpg (806.89 KiB) Viewed 8191 times
- Focus Assy 09_extracted copy.jpg (699.78 KiB) Viewed 8191 times
- Focus Assy 05.jpg (1001.27 KiB) Viewed 8191 times
