I would like to propose a new FL2 code:
SQ = Squib
For measurements of EV, CU, VO we need a distinction between signals
generated by the central unit or an external airbag timer.
For details see the attached pdf document.
New Fine Location 2 Code "SQ" = Squib
- Proposal_FL2_SQ.pdf
- pdf document
- (59.47 KiB) Downloaded 963 times
Re: New Fine Location 2 Code "SQ" = Squib
discussed at net meeting 1 July 2011 and agreed.
DV to put into database 1.6p3.
