Arm assembly
Arm assembly
On the current S2 figure, it lists many channels for the arm. In fact this is the so-called 18-channel arm from Humanetics part no IF-705. This arm is also listed as an option for the HF dummy.
What I propose is to add another page to the PDF with the arm assembly and its codes as an optional item and then use this page for both S2 and HF dummies. This, I think, will make the figures less busy and easier to maintain.
I have never seen the arm assembly. Does it replace the existing stub arm on the S2?
Paul
Return to “SID IIs (S2)”
