Transducer - Transfer Functions
Posted: Wed Sep 03, 2014 11:09 am
in the MME version 1.6 only the exchange of linear and 3rd order polynomial regression calibrated channels has been described.
A new situation arises with the nonlinear transducers of the IR-TRACC.
To handle IR-TRACC displacement and angle transducers similar to all other transducers
we want to propose a system of descriptors for channel data files covering the needs of all known use cases .
This solution also gives flexibility for future developments.
A central element of this solution is the new descriptor .Transfer function used
Dependent on this descriptor a set of parameters (new or existing descriptors) used for the calibration has to be exchanged.
For details please see the attached presentation.
Kind Regards
Peter Derpmann-Hagenstroem
