Main document - History
Proposal 2 of the main document for MME 2.0 from 08.10.2007.
Proposal 3 of the main document for MME 2.0 from 06.03.2008.
Proposal 4 of the main document for MME 2.0 from 04.09.2008.
Proposal 5 of the main document for MME 2.0 from 14.01.2009.
Proposal 6 of the main document for MME 2.0 from 22.04.2009.
Proposal 7 of the main document for MME 2.0 from 29.10.2009.
Proposal 8 of the main document for MME 2.0 from 12.11.2009.
Draft version of the main document for MME 2.0 from 03.05.2010.
Draft version of the main document for MME 2.0 from 19.10.2010.
Draft version of the main document for MME 2.0 from 21.09.2011.
Draft version of the main document for MME 2.0 from 18.01.2012.
:!: Final version of the main document for MME 2.0 for the voting process in ISO/TC22/SC12.
Final version with color marked changes to MME 1.6.
ISO_TS13499_V2_Draft_20120131.pdf
Version with the marked changes
(260.08 KiB) Downloaded 1198 times
ISO_TS13499_V2.pdf
Final version for the voting process
(258.72 KiB) Downloaded 1087 times
ISO_TS13499_V2_Draft_20120118.pdf
draft version updated before the TF netmeeting 19.01.2012
(260.88 KiB) Downloaded 1065 times
ISO_TS13499_V2_Draft_20110921.pdf
draft version updated after the TF netmeeting 23.09.2011
(260.85 KiB) Downloaded 1043 times
ISO_TS13499_V2_Draft_20101019.pdf
draft version updated after the TF netmeeting 08.09.2010
(53.32 KiB) Downloaded 1051 times
ISO_TS13499_V2_Draft_20100503.pdf
draft version
(53.32 KiB) Downloaded 1123 times
ISO_TS13499_V2_proposal8_20091112.pdf
proposal 8
(95.42 KiB) Downloaded 1216 times
ISO_TS13499_V2_proposal7_20091029.pdf
proposal 7
(94.58 KiB) Downloaded 1169 times
ISO_TS13499_V2_proposal6_20090422.pdf
proposal 6
(93.46 KiB) Downloaded 1189 times
ISO_TS13499_V2_proposal5_20090114.pdf
proposal 5
(93.32 KiB) Downloaded 1062 times
ISO_TS13499_V2_proposal4_20080904.pdf
proposal 4
(51.91 KiB) Downloaded 1172 times
ISO_TS13499_V2_20080306.pdf
proposal 3
(53.13 KiB) Downloaded 1144 times
ISO_TS13499_V2_20070903.pdf
proposal 2
(73.31 KiB) Downloaded 1117 times
