RED A (1.6) - Examples and Hints - Revision 2
Examples and Hints
Attached you´ll find the current working version of ISO TS 13499 RED A.
07.03.2016 - Changes to the ISO published version 1.6 Rev1 are marked in red color:
  • A.2.2.9 Test channel files - Polynomial calibration replaced by A.2.2.10 Test channel files - Transfer function
  • A.2.2.10 Test channel files - offset post test included into new A.2.2.10
  • A.2.2.11 Test channel files - Transducer damping ratio moved to new A.2.2.9
ISO_TS13499_RED_A_V16Rev2_20160307.pdf
working version
(154.08 KiB) Downloaded 1563 times
Re: RED A (1.6) - Examples and Hints - Revision 2
As an additional change chapter A.2.15 has been updated
with the hint to the subdirectory ‚Equipment‘ for EQX data.
In this chapter the subdirectory names for busdata and simulation have to be renamed
from uppercase notation to ‚Busdata‘ resp. ‚Simulation‘.
_
ISO_TS13499_RED_A_V16Rev2_20191104.pdf
updated proposal with marked changes to Rev 1
(167 KiB) Downloaded 1083 times
_
the final version (black color) of RED A 1.6 Revision 2 is:
2020_06_17_ISO_TS13499_RED_A_1_6_2.pdf
(645.38 KiB) Downloaded 1242 times
Return to “RED A (1.6.x)”
