WorldSID Angle for WS Ribs in X direction
there exists some designs that are able to measure the angle around the X-axis for the
rib deflection measurement on the WorldSID. This is actually not required for the calculation of the
2D rib deflection for the WorldSID (ANZ is used here).
Nevertheless we should provide a code (as additional channel) to include this option in the reference figures.
The proposal will be:
??SHRI LE/RI 00WSANX?
??TRRI LE/RI 01WSANX?
??TRRI LE/RI 02WSANX?
??TRRI LE/RI 03WSANX?
??ABRI LE/RI 01WSANX?
??ABRI LE/RI 02WSANX?
p.s. I have added the SHRI code now.
Re: WorldSID Angle for WS Ribs in X direction
Decision of the TaskForce:
  • the codes are accepted,
  • a comment in the DataBase shows, that there is no related figure, the codes are only for additional sensoring
the relates ANX codes are now listed in the Possible Channels as follows:
2020-02-05 20_20_04-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_02_Versi.png
2020-02-05 20_20_04-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_02_Versi.png (66.67 KiB) Viewed 13234 times
WS_ANX_option_for_RIBS.zip
(51.24 KiB) Downloaded 920 times
