THOR: different version of Nij
Posted: Thu May 20, 2021 3:24 pm
by bjoern.hohage
for THOR we have over the last years different definitions ofthe Nij calculation:
"NHTSA US-NCAP RfC1" with Critical force (tension or compression) in [2520/-3640] & Critical moment (flexion or extension) in [48/-72]
"NHTSA US-NCAP RfC1 - cNij" with Critical force (tension or compression) in N [3216/-4227] & Critical moment (flexion or extension) in Nm [67/-94]
"NHTSA US-NCAP RfC2" with Critical force (tension or compression) in [4200/-6400] & Critical moment (flexion or extension) in [88.1/-117]
"NHTSA Injury Criteria Sept'2020" with Critical force (tension or compression) in [4200/-4520] & Critical moment (flexion or extension) in [60/-79.2]
How to handle this to have unique channel names for all of this calculations? I think that when you have a new calculation you need a new channel name to document the calculation procedure.
Our internal proposal - we create new main locations:
"NHTSA US-NCAP RfC1" -> NIJC
"NHTSA US-NCAP RfC1 - cNij" -> CNIJ
"NHTSA US-NCAP RfC2" -> NIJ2
"NHTSA Injury Criteria Sept'2020" -> NIJ3
Björn
PS.: in the moment inside 13499 - 1.6.2:
NICF Calculation NIC Load Duration 1.3
NICR Calculation NIC, Rear Impact 1.3
NIEF Calculation Neck Injury Criterion ENCAP 1.4
NKMC Calculation Nkm Criterion 1.6
NIJC Calculation Nij Criterion 1.3
Re: THOR: different version of Nij
Posted: Wed Jun 09, 2021 1:42 pm
by Klaas
People go back and ask the specialists in their surroundings.
Björn Hohage proposes NIJ3 because it resembles the ecosystem he needs it for.
Other suggestions are sought after.
Posted: Mon Jan 17, 2022 6:35 pm
as dicussed on the last meeting I have now prepared in the "Possible Channels Table" in the database the code variants for the different NIJ intercepts that have been published over the time.
2022-01-17 19_33_08-Window.png (141.95 KiB) Viewed 21052 times
Details are given in the table in the "Remarks" column.
Please inspect the attached image. Any comments are welcome.
In RED B these codes will appear now at the end of the TH section like this:
2022-01-17 19_17_51-Window.png (42.55 KiB) Viewed 21052 times
