Digital Inputs in EQX
This technical specification defines a data format to exchange data that is relevant for exchanging and using measurement equipment between calibration service providers, laboratories and requestors in vehicle safety testing.
You will find here additional documents for the usage and implementation of the standard (XSD, demo data).
The ISO TS 23520 base document is available via the ISO organisation.
Moderator: AK-ISO-MME
Stefan
Company: General Motors
Post by Stefan »
I am proposing to add additional input definitions to the EQX Schema to handle Digital and Contact signals. For example, "Time of Contact" switches, Digital events (e.g. from the test apparatus), etc.
I would suggest adding additional enumeration values to EqxElectricalMethod:
<xs:enumeration value="Contact, NO"/> <!--Contact Closure, Normally Open-->
<xs:enumeration value="Contact, NC"/> <!--Contact Closure, Normally Closed-->
<xs:enumeration value="Transition, LH"/> <!--Digital Transition, Low to High-->
<xs:enumeration value="Transition, HL"/> <!--Digital Transition, High to Low-->
What does the group think about this?
Regards,
Stefan
gieschef
Company: ZF Automotive Germany GmbH
Re: Digital Inputs in EQX
Post by gieschef »
Hello Stefan,
we will bring this up for discussion in next taskforcemeeting, i will invite you as well.
Beste regards,
Frank
Return to “Documents and RED (XSD, demo data)”
