- AIRB - including new MainLocations
- WPL - more testobjects allowed
- SEAT - no change to Revision 1
Proposal 20170106 - MME 1.6 Revision 2
- ISO_AIRB_16R2_20170215.pdf
- update with new comment on interaction airbag
- (412.79 KiB) Downloaded 1653 times
- ISO_WPL_16R2_20150415.pdf
- 1 page
- (249.89 KiB) Downloaded 1751 times
- ISO_AIRB_16R2_20161124.pdf
- 2 pages
- (411.65 KiB) Downloaded 1728 times
Re: Proposal 20170106 - MME 1.6 Revision 2
The Head Airbags mounted in the RoofFrame (ROFR) are listed in the possible codes section
on page 1 of ISO_AIRB_16R2_20170215.pdf as ??ROFR????AH and ??ROFR????GH.
But in the picture from the left side ?4ROFR was used.
This leads to the code ?4ROFR for the left and ?6ROFR for the right side.
In the meantime separate airbags for the front and the rear part of the passenger cab are developed.
To reflect this development and avoid ambiguities the code in the picture should be changed to ??ROFR.
- ISO_AIRB_16R2_20180613.pdf
- same content, date of page 2 corrected
- (455.88 KiB) Downloaded 1642 times
- update of the position of ROFR airbags in the picture
- (443.9 KiB) Downloaded 1607 times
Proposal 20181122
The positions of the Interaction Airbags are free.
This requires an update of the figure AIRB page 1.
For the discussion please see:
https://www.iso-mme.org/forum/viewtopic.php?f=38&t=571
Figure SEAT updated from Rev1 to Rev2
and deleting some blank lines.
- ISO_SEAT_16R2_20190717.pdf
- change of revision nr, date and blank lines on page 1
- (814.66 KiB) Downloaded 1513 times
