Proposal 20170106 - MME 1.6 Revision 2
  • AIRB - including new MainLocations
  • WPL - more testobjects allowed
  • SEAT - no change to Revision 1
ISO_AIRB_16R2_20170215.pdf
update with new comment on interaction airbag
(412.79 KiB) Downloaded 1261 times
ISO_WPL_16R2_20150415.pdf
1 page
(249.89 KiB) Downloaded 1369 times
ISO_AIRB_16R2_20161124.pdf
2 pages
(411.65 KiB) Downloaded 1322 times
Re: Proposal 20170106 - MME 1.6 Revision 2
The Head Airbags mounted in the RoofFrame (ROFR) are listed in the possible codes section
on page 1 of ISO_AIRB_16R2_20170215.pdf as ??ROFR????AH and ??ROFR????GH.
But in the picture from the left side ?4ROFR was used.
This leads to the code ?4ROFR for the left and ?6ROFR for the right side.
In the meantime separate airbags for the front and the rear part of the passenger cab are developed.
To reflect this development and avoid ambiguities the code in the picture should be changed to ??ROFR.
ISO_AIRB_16R2_20180613.pdf
same content, date of page 2 corrected
(455.88 KiB) Downloaded 1259 times
update of the position of ROFR airbags in the picture
(443.9 KiB) Downloaded 1214 times
Proposal 20181122
The positions of the Interaction Airbags are free.
This requires an update of the figure AIRB page 1.
ISO_AIRB_16R2_20181122.pdf
updated figure
(452.56 KiB) Downloaded 1466 times
For the discussion please see:
https://www.iso-mme.org/forum/viewtopic.php?f=38&t=571
Figure SEAT updated from Rev1 to Rev2
and deleting some blank lines.
ISO_SEAT_16R2_20190717.pdf
change of revision nr, date and blank lines on page 1
(814.66 KiB) Downloaded 1129 times
Return to “Restraint systems and seats”
