channel codes of tracking datas
ucarstensen
Company: Faurecia automotive seating GmbH
Post by ucarstensen »
I'm looking for a definition for channel codes of tracking datas.
In the appendix you find my proposals for all tracking channels we used at faurecia.
I know some tracking points very specially but some are standard.
As important I regard tracking datas of lowspeed tests, for example BioRID.
Are already codes defined?
Bets regards
Uwe Carstensen
faurecia_H3_FMVSS202a_designation_tracking_channels.pdf
FMVSS202a
(41.34 KiB) Downloaded 1172 times
faurecia_designation_tracking_channels.pdf
general
(142.49 KiB) Downloaded 1210 times
faurecia_BioRID_designation_tracking_channels.pdf
BioRID
(42.31 KiB) Downloaded 1015 times
Uwe Carstensen
FAS R&D - Global Validation Services
Faurecia Automotive Seating
Garbsener Landstraße 7
30419 Hannover
Germany
uwe.carstensen@forvia.com
Re: channel codes of tracking datas
up to now for filmanalysis tracking data no special coding is standardized.
But there are some general rules which can be applied to this kind of codes.
Currently a group of german car manufacturers is working on filmanalysis of whiplash tests.
I will try to get a harmonized list of codes from this group.
For now I will give your my opinion to your proposal
  • channels attached to the seat are not related to the dummy type
  • the FineLocations RI/LE should replace IN/OU
  • LE/RI should be the FineLocation1
  • the CenterofGravity CG is not at the side of the head -> should be MI
For the whiplash procedure this results in the attached proposal
Filmanalysis_ChannelCodes_for_Whiplash_20100830.pdf
proposal VW for whiplash filmanalysis channel codes
(29.64 KiB) Downloaded 1282 times
ucarstensen
Thank you very much for this information.
Regards
Uwe Carstensen
Uwe Carstensen
30419 Hannover
Germany
Included on Whiplash figure.
Item closed at on-line meeting 20120216.
