The current proposal for the Testtypes, Subtypes and Regulations of Dummy Certification Tests is stored here.
In addition all measured channels are listed for every Subtype.
Dummy Certification
Dummy Certification
- DummyCertification_20170216.xlsx
- Updated proposal from 16.02.2017: all filterclasses P
- (5.18 MiB) Downloaded 1577 times
- DummyCertification_20170105.xlsx
- Updated proposal from 05.01.2017
- (5.18 MiB) Downloaded 1444 times
- DummyCertification_20160628.xlsx
- Updated version after discussion in webmeeting 28.06.2016
- (5.16 MiB) Downloaded 1428 times
- DummyCertification_20160622.xlsx
- Updated proposal from 22.06.2016
- (5.16 MiB) Downloaded 1480 times
- DummyCertification_20160303.xlsx
- Updated proposal DPH
- (4.99 MiB) Downloaded 1421 times
- DummyCertification_20151026.xlsx
- Updated proposal with channel codes and figures
- (4.99 MiB) Downloaded 1538 times
- DummyCertification_20151013.xlsx
- Updated proposal including all Q-dummies
- (74.43 KiB) Downloaded 1537 times
- DummyCertification_20150911.xlsx
- Updated proposal including pedestrian impactors, some Q-dummies, THOR
- (34.32 KiB) Downloaded 1615 times
- MME-Forum_DummyCertification_20121025.xls
- List of types and subtypes of test and the related regulations for dummy certification tests
- (71.5 KiB) Downloaded 1697 times
Re: Dummy Certification
Dear Peter,
for the THOR there is a "new" Qualification Manual 08_2016 available.
The procedures and channels are the same. Only some parameters and
the corridors have changed.
We have renamed the procedure "Knee Impact Left/Right" to "Upper Leg Impact Left/Right".
So the naming corresponds to the naming in the NHTSA document.
- 2016_08_THOR-50M_Qualification.pdf
- NHTSA Qualification Manual August 2016
- (7.2 MiB) Downloaded 1589 times
The document with the THOR updates 'Qualification Manual Version'
and change of the subtypes 'Knee Impact...' to 'Upper Leg Impact...'
you will find here:
you will find here:
- DummyCertification_20180820.xlsx
- Update with THOR changes
- (5.18 MiB) Downloaded 1523 times
