Chest Deflection - MME 1.6 Revision 2 and MME 2.0
Channel codes for chest deflection measurement
As a result of the discussion at the MME TaskForce Meeting in Wolfsburg 20150128
the following figures were updated:
ISO_CHST_16R2_20150324.pdf
chest deflection - pdf version from 2015-03-24
(1.37 MiB) Downloaded 2579 times
Re: Chest Deflection - MME 1.6 Revision 2 and MME 2.0
As a result of the discussion at the MME TaskForce Meeting 20150916
the figures of page 4 were updated to correspond with the IR-TRACC discussion
and the EuroNCAP TB021 V1.1.
ISO_CHST_16R2_20150413.pdf
page 4 with updated angle origin for WS and QA
(1.38 MiB) Downloaded 2231 times
Current version with all changes since 2013.
ISO_CHST_16R2_20160512.pdf
6 pages
(1.37 MiB) Downloaded 2111 times
I have prepared a proposal for the future coding of RibEye channels.
As the RibEye software provides additional outputs based on the LED measurements, that should be
equivalent to "IR-TRACC" (or similar) devices, I have added the middle LED with "MI" in FL2.
The 2D calculated channel (Manual 5,2 Section 4.1: Corrected 2D) will correspond to the DSY of the 2D IR-TRACC.
The 1D calculated channel will correspond to a change in length of the IR-TRACC itself: DS0
This is generated in order to provide the right input for the Dummy certification routines, that uses the direct
change in length of the device.
All modified/added text parts in violet colour.
I need to redesign the code examples to fit on the page.
As always, feedback is welcome.
there has been a clever comment by BMW on the LED codes for the middle thoracis rib:
As we already have a
LM = Left Middle
RM = Right Middle
code in the database for File Location 1 (intended for Human Models, but who cares ;-) ), we should use this as a consistent coding with the upper and the lower ribs.
So for Thoracic Ribs the coding will then be:
Left Side Impact:
TRRI LU RE/MI/FR WS DS X/Y/Z  (LU = Left Upper)
TRRI LM RE/MI/FR WS DS X/Y/Z    (LM = Left Middle)
TRRI LL RE/MI/FR WS DS X/Y/Z    (LL = Left Lower)
Right Side Impact:
TRRI RU RE/MI/FR WS DS X/Y/Z    (RU = Right Upper)
TRRI RM RE/MI/FR WS DS X/Y/Z    (RM = Right Middle)
TRRI RL RE/MI/FR WS DS X/Y/Z    (RL = Right Lower)
here is the current version with the update of page 6 (RibEye for WS).
ISO_CHST_16R2_20180613.pdf
page 6 updated from version 2060512
(1.41 MiB) Downloaded 2028 times
meanwhile we received a statement from Boxboro for the implementation of the proposed codes in the RibEye software:
Yes, we can support different ISO channel codes for the WorldSID for Left and Right side mounting.
In the current version of the RibEye software the user can set the Main Location, Fine Position 1 and Fine Position 2 of the ISO channel odes in the RibEye.INI file.
The part of the INI file for the WorldSID ISO codes is shown below.
The next release of the software will have two sections for the WorldSID ISO codes, one for the RibEye mounted on the dummy left side and one for the RibEye mounted on the dummy right side. The program will automatically switch which ISO code set it uses depending on the “RibEye Pointed to Dummy” Right or Left side setting on the RibEye main screen, allowing the users to set up different channel codes for left and Right side operation.
I have attached a full copy of the current RibEye INI file. The INI file can be edited by the user and is stored in the C:\Program Files (x86)\RibEye_5.3 W10 directory on your PC.
Also see the RibEye Software User Manual 5.3-19 Oct 2017. If you don’t have the manual you can download from the RibEye tab of the Boxboro Systems website ( www.boxborosystems.com ).
Figure 4 on page 11 shows the software screen with the “RibEye Pointed to Dummy” setting.
Section 2.6 on page 12 describes the current operations using the “RibEye Pointed to Dummy” setting.
Section 2.7 starting on page 13 describes the iso code settings.
I have been working on the next software release, and I expect to release it this summer.
WorldSID iso code settings part of RibEye.ini file from current software:
; For the dummies listed below you can set Main Location,
; Fine Position 1 and Fine Position 2 - CCCC DD EE
; only put in 8 characters for each LED, with spaces between the sections as shown
;YOU MUST PUT IN EXACLY 8 CHARACTERS!!!!
; WorldSID ISO codes are used for both WorldSID 50th and WorldSID 5th Female
[WorldSID]
Shoulder Rib Rear LED = SHRI 01 RE
Shoulder Rib Middle LED = SHRI 01 MI
Shoulder Rib Front LED = SHRI 01 FR
Thorax 1 Rib Rear LED = TRRI 01 RE
Thorax 1 Rib Middle LED = TRRI 01 MI
Thorax 1 Rib Front LED = TRRI 01 FR
Thorax 2 Rib Rear LED = TRRI 02 RE
Thorax 2 Rib Middle LED = TRRI 02 MI
Thorax 2 Rib Front LED = TRRI 02 FR
Thorax 3 Rib Rear LED = TRRI 03 RE
Thorax 3 Rib Middle LED = TRRI 03 MI
Thorax 3 Rib Front LED = TRRI 03 FR
Abdomen 1 Rib Rear LED = ABRI 01 RE
Abdomen 1 Rib Middle LED = ABRI 01 MI
Abdomen 1 Rib Front LED = ABRI 01 FR
Abdomen 2 Rib Rear LED = ABRI 02 RE
Abdomen 2 Rib Middle LED = ABRI 02 MI
Abdomen 2 Rib Front LED = ABRI 02 FR"
I have asked to post the statement here and for a standard configuration file with ISO MME conform coding in the future.
Also here we got positive response:
Yes, the ISO team can post the text as a statement from Boxboro Systems as
well as the statement below.
We can also support the changes you requested for the 1D and 2D IR Tracc
calculations for saving data in the ISO MME format.
We can also make a standard INI file for the ISO MME format that the users
can select during software installation, and document it in the software
user's manual.
In the answer there was a second statement:
Note that in addition to the 1D and 2D IR Tracc calculations, the software
includes a calculation for Length Change for all 18 LEDs. This calculation
was developed by NHTSA and is described in the software user's manual (see
section 4.2 on page 34). The length change channels will use the same ISO
codes as shown in your attachment as Optional Channels (LEDS) but with the
Axis code set to "L" as is currently done in the software."
This will address the current output with an "L" in the direction code (ISO[15]).
In my oppinion this is similar to what we already have for the IR-TRACC (or equivalent devices):
Here we code the "change in length" with DS0.
So my proposal is, to use this concept also also with the RibEye distances for the LED's.
As the LED codes are unique this should be a distinct definition.
So my proposal is for the change in length/distance:
SHRI LE RE/MI/FR WS DS 0
TRRI LU RE/MI/FR WS DS 0
TRRI LM RE/MI/FR WS DS 0
TRRI LL RE/MI/FR WS DS 0
ABRI LU RE/MI/FR WS DS 0
ABRI LL RE/MI/FR WS DS 0
As always, all comments are welcome.
By the way: Many thanks to Boxboro (and MG-Sensor) for the quick response and cooperative implementation
of the proposed codes.
here is the current version with the updated top line (date set to 2018).
with reference to 2018 instead of 2013
(1.42 MiB) Downloaded 2056 times
the Chest Defection figure is updated:
IR-TRACC was substituted by MTRAC.
ISO_CHST_16R2_20200219.pdf
(948.62 KiB) Downloaded 1882 times
Chest Deflection - MME 1.6 Revision 2 and MME 2.1
here you find the official final version of the chest deflection figures.
In the documents from 17.06.2020 on pages 1 and 2 the Note text had to be updated:
change of MTRAC to TRAC for 1dimensional cases
Please use the version 20201125 with the bugfixes.
ISO-CHST_20201125.pdf
Final official version with bugfixes on pages 1 and 2
(947.28 KiB) Downloaded 1657 times
ISO-CHST_20200617.pdf
(947.41 KiB) Downloaded 1831 times
Return to “Chest Deflection Measurement”
