New physical dimension VF for 'Volume Flow'
gieschef
Company: ZF Automotive Germany GmbH
Post by gieschef »
To describe volume flows of gases or liquids we Need to describe those measurements by a new physical Dimension.
Proposal would be 'VF', our used unit for this would be 'l/min', SI unit is propably 'm*m*m/s'
Re: New physical dimension VF for 'Volume Flow'
Hi Frank,
seems you are in a "flow" today :D
Same as for your mass flow proposal:
  • No interference with existing codes.
  • Proposal prepared for discussion and decision making.
added to database with the name: "Volume Flow Rate" (2019-04-10; 1.6.2p3):
Mass_Volume_Flow Rate.png (5.75 KiB) Viewed 14084 times
Topic closed during NetMeeting 2019-07-17
